What pushrods, springs, and roller rockers?
Old Feb 4, 2006 | 11:51 AM
buck2769's Avatar
Default What pushrods, springs, and roller rockers?
This weekend I'm bumping the boost up to around 10#'s or more. To avoid valve float I'm replacing the valve springs and I figured I might as well hit the pushrods and rockers while I'm in there. Which pushrods, springs, and roller rockers should I use? What do you use?
Old Feb 4, 2006 | 10:35 PM
EPP's Avatar
EPP
I'd go with the Comp 918's and Comp 7.4" pushrods, and keep the stock rockers, which on the LS engines are a really good design. They don't flex like the old school sm blk Chevys do. Bob
Old Feb 5, 2006 | 10:27 AM
buck2769's Avatar
so I wouldn't need or benefit from the dual spring kits?
Old Feb 5, 2006 | 10:36 AM
turbo'd stang's Avatar
Need some cam specs to get a ballpark of what springs you need. Valve diameter and boost also determine how much you need.
Old Feb 5, 2006 | 01:52 PM
buck2769's Avatar
stock cam and valves
Old Feb 5, 2006 | 04:11 PM
EPP's Avatar
EPP
I was running 14 psi of boost on 126,000 mile springs, probably not the smartest thing to do... all you need are the 918's for your engine. Bob
