turbo?
Old Feb 5, 2006 | 02:25 PM
vitamanz's Avatar
Default turbo?
I have a strkd,409 iron blk.,oringed,8.5/1,9/16 studs,ross,lunati,said to hndl 30psi.,overkill yes this mtr is all new never run yet!I want 10sec. quartrs,I hv 80#psi. inj.,low imp.,90mm. tb.,ls6 intk.,would like to keep air cond.,I will do t400.,9in. rear I have x duty tq. arm,bmr sub frm.,QAI,ebach car is lowered 2 in.,wolfe bar, what turbo set up that I can close the hood and forget about it I dont need to sqze.,everything out of it AND I DONT WANT IT HITTING THE GROUND ! THERE IS ALWAYS SOMETHING FASTER dont care not into street racing either Thnks Eric M
Old Feb 5, 2006 | 04:53 PM
smokinHawk's Avatar
if your only wanting 10 second quarters you should be able to do that alone with your 408 (if you raise the CR)
to work with your setup and desires best i could sugest is the PTS turbo kit (ptk) with the largest AR they have, should only need to use like 10psi to get there.
