SLP radiator with LS1 procharger kit?
Old Feb 7, 2006 | 04:23 PM
Lawnboy's Avatar
Restricted User
Default SLP radiator with LS1 procharger kit?
Does anyone have the SLP 50% more core Radiator installed with a P1-D1-SC
procharger kit and Procharger fan shroud,
Please let me know
I would like to install one of these SLP Radiators with my F-body LS1 D1-SC procharger kit,
I need to know will the prochrager fan shroud still fit with the 16" Spal extreme fan and if there is still enouge for the D1's air intake Hat.
thank you for your help
Old Feb 7, 2006 | 04:43 PM
strokedls1's Avatar
My friend has a lt1 radiator with the ati fan setup and it works ok. The slp radiator is just a lt1 radiator with a block off plug already installed on the heater core outlet.
Old Feb 7, 2006 | 05:20 PM
Lawnboy's Avatar
Restricted User
heater core out let blocked off??? why is that
is the SLP radiator any better??
is it a double row
Old Feb 7, 2006 | 05:26 PM
618HAWK's Avatar
I have the SLP and a D1SC, with the ATI SPAL-Fan and shroud, Not using the stock ATI hat though. But there is enough room, the shroud sits on the tank flanges and they are the same thickness no matter which radiator you are using LT1 SLP LS1. All the tanks are the same dimensions. So the shroud will be at the same location. You should be fine.
Old Feb 7, 2006 | 05:30 PM
618HAWK's Avatar
is it a double row
Not a big deal that is the way SLP mods and send them out.
