Blowing Dip Stick Out
But from what you guys are saying, a breather IN ADDITION to my PCV into the catch can into the s/c inlet is still a good idea for boost. I looked at some breathers on Summit, but I didn't see any that sounded like they'd fit my Nasty valve covers. I have the 1.25" screw-in billet oil filler cap. Any suggestions?Older Toyotas have a check valve on the brake boosters with 3/8" hose fittings on both ends if anyone wants to take that route. But it's a dealer-only part....
How exactly do have your catch can/PCV/hose to the inlet/valve cover hooked up?
I use the LS6 valley to PCV valve to AMW catch can to check valve to Intake. Then use a breather on each valve cover.
Question: you have your pcv (via catch can) going back to the intake for recirculation, like normal. I get that avoids smelling up the place, but the can stops oil from going into intake. I like those two concepts.
But then you have breathers on the covers. I also get that's to fix the /boosting + closed crankcase = no more seals/ problem, but doesn't that totally ruin the "my car doesn't smell like an oil drum" fix you did by recirculating it in the first place, since it is just going atmo at the valve covers?
Sorry if I am not getting it...
Clint
I still use a PCV though, keeps the oil a little cleaner if you street cruise a lot - maybe
I probably dont need the PCV anymore but I am too lazy to change anything and it works OK for me..
1.Disconnect your vacuum hose from your PCV and put you thumb to it while the car is running - if the thumb sucks in - your lines are good, if not - check the line for cracks and clogs starting from the end you got in your hand down to the intake manifold. Most likely you'll have to replace it.
2. If lines are good, take out your PCV valve and shake - if doesn't rattle - go get new one.
3. If it does, put your PCV valve in and connect it.
4. Open the oil cap on the valve cover with the engine running.
5. Take a piece of paper(3x5 card) and put it over the hole - if it stays on - PCV valve is good. If it blows out - replce the PCV valve
I hope it helps, let me know the results
Sincerely,
Valera
To install a breather filter, you need to plug the vacuum line coming off your manifold. Then you need to put some type of a tube on top of the valve over hole for PCV valve and attach a breather filter to it. Breather filters can be found in your local Autozone/Advanced Auto Parts. It looks just like a ram air filter, but only about 2-3in in diameter and about 2.5-3in high.
Sincerely,
-Valera-
Anyhow, at idle and cruise the PCV is pulling air through the breathers in the valve covers, through the crankcase, through the catch can and then into the intake. WOT is pretty much the only time the PCV is closed and not drawing through the crankcase so both things work but at different times. If the car was WOT all the time then it would smell like a used can of oil but since 98% is part throttle/high vacuum the PCV works just fine. Only downfall is you now have unmetered air and the idle/maf tuning get a little weird but its easy enough to fix and is no concern if you run an SD tune.
Where in the intake stream are you routing the recycle line?
Does it make a difference if you have a catch can?
Because the rest of it does not keep the turbo from pressurizing the case and forcing things out of places, unless I got confused.
I have an additional question for you. It seems that having vacuum on the crankcase is a good idea for various reasons, but figuring out what to do with the product of that vacuum is the problem, if you still want to relieve the pressure forced induction causes.
Are these two goals simultanesously acheivable in the same system, or not? Could you route it such that under boost the pressurized mix from the crankcase is evaced (PCV style, yet not PCV since it is closed under boost) and routed back into the induction system preturbo to be cooled, measured and burned again (post catch can, to remove oil) instead of sent straight back into the TB, which is where the pressurization occurs (among other unwanted side effects, which is why peple disconnect and cap that TB input)?
Also, for people who do not route their post catch can air back into the system somewhere, are you experiencing any water in your oil from moisture collecting in the crank case instead of being sent to the intake and burned?
Sorry for all the questions, I spent hours researching this and came up more confused than I started.
