which headgaskets ?
Old Feb 9, 2006 | 03:14 PM
Bad30th's Avatar
Default which headgaskets ?
Pulling the heads soon to check to see why I'm blowing white smoke at WOT.
Which headgaskets should I go with when I put the heads back on ?
I used stock GM MLS before... I wouldn't mind putting something "beefier" in there... I'm using ARP head studs if it matters.
Wish me luck that I don't find anything serious.
Rob (Bad30th)
Old Feb 9, 2006 | 06:32 PM
67Ranger's Avatar
ive always heared GM MLS are plenty beefy for anything you can throw at them.
Old Feb 9, 2006 | 06:33 PM
Bad30th's Avatar
Search is crippled, someone throw me a bone here...
I know Cometic makes some good ones for FI, right ?
What sponsor should I call and order from ?
Rob (Bad30th)
Old Feb 9, 2006 | 06:35 PM
Bad30th's Avatar
Hehe, great timing with the reply ! Right before I posted, lol.
Thanks for your reply.
OK, one vote for MLS... Anyone else wanna chime in ?
Rob (Bad30th)
Old Feb 9, 2006 | 06:40 PM
kp's Avatar
kp
If you had stock graphite gaskets the stock GM MLS is a step up, lots of cars running them with good results. Cheap too
Old Feb 9, 2006 | 06:47 PM
TwnTrboCE's Avatar
Stock GM MLS is all you need. That is what I run on my CE. Harlan ran them on his car as well. If you can't get these gaskets to live then your tune is off or you have some other issues(bad).
Old Feb 10, 2006 | 08:49 AM
Bad30th's Avatar
Thanks guys. GM MLS it is...
Rob (Bad30th)
