Is the only difference between a TT and a T set-up.....
Old Feb 12, 2006 | 02:05 PM
turbocuda's Avatar
Originally Posted by Moparnos (The SLP Guy)
nice name Turbocuda, i hope you got one
I wouldn't pose like that!
Attached Thumbnails Is the only difference between a TT and a T set-up.....-turbocuda1-2.jpg   Is the only difference between a TT and a T set-up.....-3.jpg   Is the only difference between a TT and a T set-up.....-cuda-pics-004-3.jpg   Is the only difference between a TT and a T set-up.....-small-intercooler.jpg   Is the only difference between a TT and a T set-up.....-small-resevoir.jpg
Old Feb 12, 2006 | 03:04 PM
XJGPN's Avatar
Originally Posted by gametech
Strictly from a physics standpoint, it is always going to be possible to make twins boost earlier than a single at the same peak flow and efficiency ratings.
Not true. The logic behind this "theory" is that it is easier to spin up the "smaller" turbo than it is to spin up the larger turbo. The truth is that you have 8 cylinders spinning the one large turbo vs. 4 cylinders spinning up each of the 2 in a twin setup (on an 8 obviously). There have been companies that have done experiments trying to go with fully optimized twin setups and single setups to compare lag, and I have yet to see a company beat out a single setup with a comparable twin setup. Fact of the matter is that the most important factor with determining spool is the turbo... both matching the turbo to the setup and just the technology within the turbo. The second most important factor is the "layout." Cast manifolds vs. tubular, log vs. header style, size of primaries, size of intake piping, size of intercooler. The single vs. twin debate relative to spool really is so insignificant that it really isn't even worth mentioning... especially since where your particular engine maps out at would make it switch back and forth depending on which twins would feed it properly vs. which single. On turbo engines, managing heat really is the main thing you should be worrying about… All this talk of single vs. twin is really misplaced attention. Make that decision based on what “fits” the engine bay better… Not based on spool characteristics.
Old Feb 12, 2006 | 09:15 PM
Quickin's Avatar
Thank you for clarifying my point in a much more tacktful manner.
Andrew
When I post a question I expect answers or any info that can reach an answer, not "the question kills me"..."get a grip"..."the car will be undriveable on the street".
What kind of reply did you expect?
Old Feb 12, 2006 | 09:18 PM
Quickin's Avatar
Well, I guess the single turbo is the way to go for me anyway. With the big cubes the turbo should spool very soon and be more controllable throuhgout the rpm range.
Old Feb 12, 2006 | 09:19 PM
bboyferal's Avatar
There ya go...
So... what's the next step???
Old Feb 12, 2006 | 09:46 PM
Rpm2800's Avatar
Some of those seem to be valid points. Others I'm not so sure about.
Old Feb 12, 2006 | 09:59 PM
XJGPN's Avatar
We all have our moments... Feel free to correct me :-)
Old Feb 17, 2006 | 10:09 AM
lo_jack's Avatar
Hey I have a related yet slightly stupid question I would like to have clarified.
I know when you are looking at engine demand on airflow, if you have two turbos, they can each do half the work (assuming correct sizing) to make the engine need. So if you need 50lb/min, two that make 25 will do.
But is PSI cumulative, the higher of the two (for the sake of argument, say they were different) or the same (eg turbo 1 10psi and turbo 2 10psi = 10psi)?
In other words one turbo at 12 psi is 12psi, but are two at 6 = 12 or 6?
Coming back to the original question, how does that effect power generation at lower rpms, as someone else mentioned?
Old Feb 17, 2006 | 11:30 AM
Boostaholic's Avatar
I'll tell you something about my TT setup quicken, if you want wheelspin off the line boost will do it in a single or twin setup on a TH400 setup and a descent converter. I will be very happy again when I can hook up enough to get full boost in 1'st gear
Old Feb 17, 2006 | 01:17 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Lyle, a big single will have more backpressure than twins at the same target power level. Look at it this way, (2) three inch holes flow more than (1) five inch hole. But you can make 1500 hp with either setup. My guess is that the spool time of a big single will be noticeably slower than twins, but we'll see.
Old Feb 17, 2006 | 01:46 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
that is so f'ing sweet.
Old Feb 17, 2006 | 02:56 PM
  #32
smokinHawk's Avatar
HOld ON JohN!
one 5" hole flows more then two 3" holes
Pi R^2 dont you remember from geometery class
a 5" pipe is 19.63 square inches (least on the outside diameter you have to subtract wall thickness but we will ignore that)
a 3" pipe is 7.07 square inches multiply that by two and its 14.14 square inches
So the 5" pipe has better flow amount, not to mention the friction of the added walls going through two pipes, but you might not know that unless you took fluids.
one 4.5" pipe = two 3" pipes (not counting the friction of the walls of the pipe)
Old Feb 17, 2006 | 03:56 PM
  #33
LTLHOMER's Avatar
Originally Posted by smokinHawk
HOld ON JohN!
Let's not get into relative roughness and K values for different type of bends...haha or else we'll be breaking out the Moody charts. Sorry fluids flashback.
Old Feb 17, 2006 | 03:58 PM
  #34
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Nice looking Mopar.
Lyle,stop talking about it and do it. Hope you budget for all the supporting hardware you're going to need.
Old Feb 17, 2006 | 04:31 PM
  #35
here is my mopar, i had a 70 and 73 cuda about two years ago. i regret getting rid of them.
i'm planning on running a procharger on it this year but we'll see what happens after i finish the camarslow
Old Feb 17, 2006 | 04:48 PM
  #36
Quickin's Avatar
I don't want wheel spin off the line, or anywhere else. I'm just used to having raw N/A power ~500/500 off the line and it's instant, and smooth power when it comes in, easily controlled all the way through every gear.
Since a 1,500 RWHP set-up can't be nailed to the floor off the line, I'm just wondering if a single turbo will be all over the place off the line. Or if I want to take off as fast as possible without wheelspin, will it reach a point where the boost will just pound the engine and the wheels will spin.
A big stroker like a 427 should have enough torque off the line, but it would suck if it reached a certain rpm and just blows the tires off uncontrollably. I'd hate to have a single turbo setup built and this be the characteristics. It would get sold.
Old Feb 17, 2006 | 04:51 PM
  #37
lo_jack's Avatar
Woo for a big orange engine. I have one in my garage but I am too lazy to put in my mopar. Great looking car.
and wouldnt a smaller cross section pipe fill up faster (assuming again correctly sized turbos), and therefore lead to faster spooling?
Old Feb 17, 2006 | 07:07 PM
  #38
turbocuda's Avatar
Moparnos, here is a vid from when I first put the injection on....Slipping going into high gear and fuel issues laying over in high gear...
http://www.boostdoctor.com/clips/brian680.wmv
Old Feb 17, 2006 | 08:26 PM
  #39
LIL SS's Avatar
Moderator
Why?
I think 2 twins might spool slower. Half the exhaust flow to each twin.
Old Feb 17, 2006 | 09:33 PM
  #40
Slowhawk's Avatar
LS1Tech Sponsor
Just going by PurEvl's setup with a 408 T88 Turbo setup I would hate to do aggressive driving on the street with it ussing an A4 unless it had a manual valve body. This is why. The car is very drivable and it's easy to control traction with throttle control but if you hit it to the floor it will spool and blow the tires off,nail the rev limiter -even at 90mph (Nitto 315's) .Now take an A4 in drive. You go heavy from a stop light,the Turbo spools and the next thing you know the speedo is pegged because it went through the gears.So your going 60mph but the tires are going 180mph.This makes the car hard to control if it decides to go sideway's because the tires have no chance of grabbing while they are spinning that fast. Sometimes it is still fun though.
I also see how you got bored of the 500hp.That is a normal # around this area. When you do 800-900rwhp you will think the car is slow then too after you get use to it
