Turbo Mounting Angle
Old Feb 12, 2006 | 04:58 PM
bigturboz28's Avatar
Default Turbo Mounting Angle
I know the oil inlet should be at 12 o'clock and the oil outlet should be at 6 o'clock (when you spin centre section). But what the limits of rotating in the other plane (the one that when the turbo intake goes up, the turbo exhaust goes down)?
Old Feb 12, 2006 | 05:32 PM
whynot's Avatar
from what I have been told, it should be as level as possable.
Old Feb 12, 2006 | 05:51 PM
That makes sense, but what are the limits, does anyone have anything slightly tilted, what angle?
Old Feb 12, 2006 | 06:23 PM
Darren P's Avatar
I think around 45 degrees and less is better
Old Feb 13, 2006 | 01:07 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
That is correct. You don't want more then 45 degrees from 0 in either direction, which 0 is 12 o'clock position.
Jose
