Dropping stock comp.
Old Feb 13, 2006 | 04:06 PM
HellRaiser's Avatar
Default Dropping stock comp.
I wanna drop the stock compression (stock motor) a little for the next setup and was wondering what I should look for. I thought I read you can use the truck heads to drop it like a point or so. If this is true what heads should I look for exactly?
Old Feb 13, 2006 | 04:14 PM
frcefed98's Avatar
317 6.0 truck heads should net you 9.5-1 comp
Port and polish should bring that down a tad more.
Old Feb 13, 2006 | 04:22 PM
White.Lightning's Avatar
Thats what I am doing. Add some stronger springs/pushrods and a mild home port/polish with some MLS gaskets and you are good to go!
Andy
Old Feb 13, 2006 | 08:03 PM
HellRaiser's Avatar
Thanks Jer!
I have the springs just need the push rods.
