LS1 S-10 Turbo
Old Feb 15, 2006 | 02:26 PM
lowonair6173's Avatar
Default LS1 S-10 Turbo
just got the motor for my truck, im getting some 6.0 heads with stainless valves and all the good stuff, already ported and polished and then a turbo cam, im gonna use the 5.3 truck manifolds and make my own intermediate pipe but now that im shopping for a turbo im not sure how boost i should try to run? the whole lower end is stock including the pistons, but i do have the double roller and a ported and polished oil pump, i am also gonna be running a 1050 carb. so if anyone has any idea what the maximum boost im gonna be able to run with this setup.. thanks in advance.
Old Feb 15, 2006 | 02:27 PM
o yea im also gonna be running ARP studs for the heads and manifolds and a couple other parts
Old Feb 19, 2006 | 06:57 PM
sparkwirez06's Avatar
Is this setup going in a S10 ? is it a 2wd? the reason i ask,is the frame rails are narrow and the 6.0 ex spread out,and there's not much room in the front,with the steering box, i have a 93 with a lsx awd been looking for a turbo manifold cure, just doesn't seem to be any short of making my own. Take a look, http://www.turbols6.com/gallery/view...yphoonz06turbo
Old Feb 20, 2006 | 08:17 AM
hellbents10's Avatar
LS1Tech Sponsor
Right there is not a ton of room at all. Its hard enough to make long tubes and just get th motor in there. The only way I could see doing it and keeping AC and all the factory stuff would be with twins and 2.5" down pipes.
Old Feb 20, 2006 | 10:22 AM
LS1Tech Sponsor
Also the 1050 is way to big for a blow thru setup less then 1400hp or so. A 750 would be good to about 1100.
