Ok.. I give up.. where is it?
Where is the post on CR conversions? There was a post that had all the CR definitions based on what heads you run on what LSX engine... even had some conversions that took gasket thickness and included that as well.
Shoot... while Im here, might as well... I have a set of 6.0L/317 heads on my LS1, off of a newer SS Silverado ... with GM OEM replacement head gaskets. What should my CR be? I know its a low 9:X.. but the conversion showed exactly what it should be.
Is there a possibility that particular post could be a sticky in one of the forums, if not this one?
Thank you...
