Anyone have success using toulene
i have also ran a mix of race fuel and strait race fuel and meth and even meth with race fuel.
alcohol injection with strait meth spraying and pump gas works prety well. i was able to run 5psi more on pump gas with the meth and on my set up that is around 200 more rwhp still on pump gas. the meth is much cheaper than any other additive especialy since you go thru so little of it. a alcohol injection kit will quickly pay for itself.
I worked with a guy named Ivan Cash at the ChevronTexaco Refinery in Pascagoula, MS. He was the Ford Lightning and Ford Turbo Diesel tuner for Runnin With the Devil Motorsports in Mobile, AL. His lightning ran mid 6's in the 8th and he always ran a 1 pintTol / 3 gal. Pump Gas mix in his truck on track days. He said the only potential problems for using Tol, was that high concentrations could kill catalyst activity on street cars...he never ran cats. He also never commented on the life expectancy of his O2 sensors either. But this was a lot cheaper than running aviation fuel (130 oct) blends (his other proven method for running higher boost levels with a supercharger.)
Bottom line: There are many ways to increase your engines tolerance for more boost; if you’re looking for something reliable, that doesn’t require guessing how much of “XX” to add to your tank, go with the Meth…it’s been proven safe and reliable. It’s kind of like nitrous I guess.
Last edited by Sixspeed02TA; Feb 23, 2006 at 02:37 PM. Reason: put in actual vol. ammounts
