Turbo heads
Old Mar 2, 2006 | 12:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'll ask Bob @ All Pro on valve sizes, I can't remember what size we went with to be honest.
What is the max CC you can get in a Trick Flow or AFR?
Old Mar 2, 2006 | 01:18 PM
RealQuick's Avatar
Is there any difference between OEM and aftermarket LT1 castings, in terms of deck thickness? If so, and if it's significant, I would go aftermarket. I don't anything about valve sizing, but I'd at least go 2.02/1.57.
Trickflows are probably the best way to go now because the trickflows can be ported to flow as well as AFR210's, but the trickflows can be used with LT1 intake as far as I know. GM discontinued the LT4 intake manifold, so the prices for the intake have gone from 250 to 1000 bucks on ebay!! So those people with the AF's (LT4 style) wil have problems if they dont have an intake yet.
Old Mar 2, 2006 | 01:48 PM
LS1Tech Co-Founder
Are all the AFR's LT4 style? There are 2 or 3 LT1 castings for LT1's?
Old Mar 2, 2006 | 01:53 PM
TurboZ28's Avatar
As far as I know all AFR LT1 heads use the LT4 intake. So the essentials are deck thinkness, large combustion chamber and... What about valve sizes? Should the exahust valve size be closer to the size of the intake valve?
Old Mar 3, 2006 | 12:00 PM
RealQuick's Avatar
They use to make a smaller LT1 head...I believe a 180cc head, then it was discontinued.
Deck thickness = Trickflow or AFR's
Larger combustion chamber = Trickflows or AFR since LT1 castings can only be opened to around 58cc.
Valve size = biggest valves are in the trickflows or AFR's (I believe mine are 2.08/1.60)
Readily available intake manifolds = LT1 intake available...... = Trickflow heads
To me the decision is easy...Trickflows or AFR's depending on if you can get an LT4 intake...
Old Mar 3, 2006 | 01:23 PM
whynot's Avatar
on the trick flow, I recived a paper with mine saying that they are available in 64cc and 72 cc's, the ones I got are 62 cc's. valve size on mine are 2.02 and 1.60 stock, but you can drop a 2.05 right in they say. but comparing stock to stock trick flows, wow, what a differance a lot better head.
Old Mar 4, 2006 | 12:15 AM
Silver02's Avatar
Does having heads that flow substantially more help with a turbo?
Old Mar 4, 2006 | 01:49 PM
whynot's Avatar
I have heard the general rule is that on 17 psi (some say 14.7, but that takes in no loss from blower or turbo set up) your car will double its na numbers, so what ever helps a na engine will help the fi engine as well.
Old Mar 4, 2006 | 03:32 PM
Race-Prep's Avatar
Suspended Sponsor
Here is my experience with this type of powerplant.
-Heads can't flow too much and any increase will net power gains.
-Deck thickness becomes a problem with the LT* engines when using stock heads and they start to have gasket problems beyond about 500+ RWHP with an auto maybe a little more with a manual I have seen them literally "PUSH" the gasket out with no signs of detonation or knock at all.
-Exhaust to Intake ratio is VERY Important when it comes to spooling the turbo well, if you are interested, we offer Trick Flow or AFR castings built for turbo applications for LT1/4's and LSX's on a custom order basis.
The bottom line is....the turbo will make great power without addressing the I/E ratio and flow numbers...but it will make more EVERY TIME with the proper port work done to the heads.
Old Mar 5, 2006 | 12:40 AM
pwrtrip75's Avatar
Running a larger cc head will have less material around the valves and flow more in the lower lift. Sometimes smaller valves will actually flow more overall, depends on the head. Most people look only at the highest number in a flow chart, but in reality the flow numbers in the lower lift is just important if not more.
Old Mar 5, 2006 | 03:32 PM
BUYAMERICAN's Avatar
This exact right. .400-.550 maybe .600, is everything especially with a turbo cam.
