STS Help!!
Old Feb 24, 2006 | 10:57 AM
JD_Z28's Avatar
Default STS Help!!
Im building a 346 long block with LQ9 heads, my compression should be around 8.9:1 Im also running an STS kit on this setup. I needed help picking a good cam to run that will still be smog friendly in CA. My plans are to run decent boost with 91 and run high boost with 110 octane. So far I was told I should run a reverse split cam 226,220,570,565,115 Im trying to get other opinions.
Old Feb 24, 2006 | 06:07 PM
JD_Z28's Avatar
Can anyone recommend a good cam.
Old Feb 24, 2006 | 07:28 PM
longrange4u's Avatar
Yea.. check out LPE GT-7 cam... I think I have the best numbers out there with a stock block. Not sure... but I think Cam has allot to do with it.
