A Tuesday treat :)
UltraDash can be used w/o BS3. BS3 can just be had with the proper input/output to make it really easy. You can use UDX to show mulitple things as is, and log some, and use RacePak's v-net system to route like 30+ things to he dash if you wanted to (obviously not everything can be seen at once). And I think it may even play stuff back. its all in the link above. They have one that shows turnsignals, etc. too for street cars.
here:
250-DS-UDXRP: This model comes standard with all the basic instrumentation needed to operate your vehicle. Standard features include engine rpm, water temperature, oil pressure and battery voltage. You can optionally add oil temperature and fuel pressure by simply purchasing the required sender. Need more sensors? The VNet port will allow you to add up to 32 additional channels for the ultimate in expandability. The UDXRP model can record up to 10 minutes of data which you can play back later on the LCD display. You can also upgrade this model to download recorded data to our DataLink PC software for complete analysis. ($795.00)
250-DS-LDX: This model offers the same features as the UDXRP, plus the additional hardware required to monitor the driveline RPM. The big difference between the two is the ability of the LDX to record the monitored functions and then download the data to a PC for data analysis using Racepak DataLink software. With a self-contained data recorder the LDX Logger Dash can be equipped with optional sensors to record up to a total of 32 channels of data. Sample rates up to 100/second, and 1 MB of memory, provides lots of recording time and sampling ability. Standard features of the LDX include shift light output (6 gear), external warning light output, internal warning indicator light, minimum/maximum recall, and a remote record/display switch. ($1395)
250-DS-UDXSR: A display only model for street rods and street machines. This model adds the features that are required on street driven vehicles, such as speedometer, odometer, high beam, parking brake and turn signal indicators. The dash also offers the ability to display water temperature, oil temperature, oil pressure, fuel pressure, fuel level, battery voltage and tachometer. ($695.00)
Got the lotion and Im off to the bathroom.
Also, what were those 2 bottles in the rear? Nitrous and a nitrogen charge? Dual power adders?
On second thought, it's probably fire suppression. Nitrous would be blue.
Kurt
That's some damn nice work guys, when are you gonna shake it down?
I guess you missed this 26 pg thread about the build-up.................
https://ls1tech.com/forums/showthrea...6&page=1&pp=20
Kyle
Kyle
great work guys.
W2W Crew
