On the road again
Richie, the water pump doesnt look that bad in person lol, its 8 years old so cut it some slack
Its a new short block with better connecting rods and the compression is about .5 less, shiny new LS6 block aslo. Also have as-cast Dart 225s on it. I was paranoid with the stock connecting rods in the other motor and the 98 heads it had before were ported back in 2000 plus had stock valves. Should pick up a little but with this stronger rods I'll be able to up the boost some. Not looking to run much faster then last year, just hoping to have another trouble free year. Next fall I'll make it fast, collecting parts now
I know. I was messin with ya/
Sounds good. Should pick up a good amount of power over the old combo. You can even upgrade to the carb-style if you wanted just a little more out of it.
I wish I knew what the approx. gain's are for the Carb style over say and LS6 for a forced induction set-up.
Using something new....... just like you are wanting...... ill let ya know.....
Kyle
