Should I go for it??? (408 build)
maybe do a ford 9 inch too!
I still need to order:
F1 Head Unit
75# injectors
HPT or EFI Live
Wideband
And some other Misc stuff
I would say 2-2.5 months and it will be installed and running! Wish me luck guys!
408" Iron Balanced, blue printed and assembled short block. Eagle 4340 4.0"
crankshaft, Callies 6.125" H beam rods, Wiseco 4.030" forged dish pistons, C&A
dura moly rings, Federal Mogal 152M main brgs, Clevite cb663 H rod brgs, Dura
Bond cam brgs, ARP main studs
assemble longblock ( Check P to V, torque down heads, Degree cam, set up valve
train)
Machine block and heads for 1/2 studs
AFR 225cc runner CNC ported cylinder heads
ARP 1/2 LS1 head studs
Cometic head gaskets
Cam Motion custom LS1 camshaft
Roll master double roller timing set w/ torington bearing & nitrided gears.
Crane Hyd. Roller Lifters LS1 #10530-16
here is a lil cut and paste from my invoice...
Good new is I already have my ET240cc heads sitting at the engine builders, and once he gets the pistons it should go together real easily! I hope atleast.
I also already put my F1C head unit on my stock motor to test fit and it does in fact fit... Only GTO with that head unit that I know of, already talked to a few shops about fitment wondering how I did it.
For now I will put a larger pulley on the F1C and get it tuned so I can still drive it. For now I will probably just add lots of fuel and Do lots of logging, especially since my LC1 should be here next week and my HPT Pro with EIO already arrived.
I am stoked about getting this thing built and together... next step is the tranny.
