dont add up....
if you can drop .2 out of the hole by spraying it will pick up .4 on the ET.
also if your shutting off the gas at 5600 you should be shifting at around 5400
if you shift say 5800 then you need to move the gas to 6000
its also highly likely your tune is not perfect. i would think a 75 wet shot would be very rich. i have a friend that runs 100 dry on stock lt1 and the stock tune holds up fairly well.
in addition i would think it would start spraying again as soon as the rpms come below 5600.. which is well before the trans stops slipping to a completed shift at say 5000rpm.
