some kind of misfire thing happening.. help
its still functioning in the car, but the harness is all cut back that used to hook to the engine.
the accel box is sold long ago, and also had a separate engine harness.
my 'try me' bs3 box is on the way.
back pressure doesnt seem bad at all 1.3:1 on a 365 cubed engine and a T4 pt88 right.
when the thing started acting up.. can't say exactly.. i was thinking i had a backpressure issue w/76mm / stock coils petering out / some valve float with the wheel iron block motor in a previous dyno session
http://www.fastrides.com/photos/mm/i.../original.aspx
so i put truck coils on and installed new plugs.. then i switched to the 88mm and it ran awesome at the last ls1 tech race... so i figured between the turbo change (lower backpressure), putting the truck coils on, and taking the slp muffler back off that it was fine again.
then well of course i blew it up that day and put the ls2 in a month later. same everything exept for cam sensor, timing cover, block, and stock cam instead of the biggish one that was in there.
uhhhhDid you switch it out before last night? I meant to chat you up a bit more but you got away early!
Already did the camsync-override stuff.
Whoops my buddy was logged on...this is LTLHOMER.
ill run into the problem again when i up the boost, havent been over 17 yet.. 11-17 seem ok. maybe 2mph down trap speed at 17psi but thats really hard to point blame.
i am waiting for w2w to have time for me to drive the car up there and let them look everything over in person.
