H&C suggestion for Procharger C6
Old Mar 16, 2006 | 01:19 AM
Brabus2's Avatar
Default H&C suggestion for Procharger C6
Looking to add a head & cam to my Procharger C6, can anyone recommend/suggest a blower cam profile & heads. Currently @ 560rwhp/501rwtq at 7PSI, I have the P1SC, ECS Alky kit, Kooks LT headers, Borla Stinger (Sport). What should I expect in terms of rear wheel gains by adding a H&C??
Any info is greatly appreciated!
Thanks.
Old Mar 16, 2006 | 02:21 AM
ChaseSS's Avatar
I don't know much but you probably want a larger combustion chamber so you can run more boost (obviously) and I think a lot a people run ported lq9 heads with FI
Old Mar 16, 2006 | 02:42 AM
LSs1Power's Avatar
Thanks.
Go with 72-74cc heads from either 215 cc ET heads or 205cc AFR. I would pick a cam with 230/236 114 LSA with .585 .595 lift. U should be looking at 80-110rwhp 40-70rwtq with 10-12psi.
Old Mar 16, 2006 | 04:42 AM
EPP's Avatar
EPP
With the P-1SC1 you are more than likely going to be maxing out the blower with adding heads and a camshaft to the LS2 engine. You may have to send it in and have it upgraded into a D-1SC, which runs $1,200.00.
You may also be looking into forging the bottom end of the engine, as you're going to be pushing the stock bottom end past what it can normally handle. I would suggest either just adding a blower friendly camshaft to your current combination, or pull the engine out and have it built with a forged bottom end. Bob
Old Mar 16, 2006 | 09:32 AM
BLWN1's Avatar
Looking at his sig, I assume sending the motor out to be forged wouln't be a problem, nice list and keep us updated on the vette....!
Old Mar 16, 2006 | 02:35 PM
Brabus2's Avatar
Thanks! This is the info I was looking for.
Old Mar 16, 2006 | 02:51 PM
Brabus2's Avatar
Bob,
Thanks for the advice! Quick question for you, would I lose low-end TQ by swaping the P1 to the D1 unit at my present setup (w/o the H&C)?
Old Mar 16, 2006 | 02:52 PM
Brabus2's Avatar
Thanks buddy...Will do!
Old Mar 16, 2006 | 04:56 PM
EPP's Avatar
EPP
Smile
Bob,
Not really, I can't tell the difference between them. Either one is going to erupt your tires into a cloud of smoke. Bob
Old Mar 17, 2006 | 12:03 AM
Brabus2's Avatar
Hahaha...Okay, Thanks Bob.
Old Apr 5, 2006 | 02:18 AM
Brabus2's Avatar
Anyone have an opinion on this particular cam - 208/230 .554 .546 121 LSA? How well would it work on my force induction setup?
Thanks!
Old Apr 5, 2006 | 04:22 AM
EPP's Avatar
EPP
Waaay to mild!!! Bob
Old Apr 5, 2006 | 08:32 AM
Nine Ball's Avatar
LS1Tech Co-Founder
that would be considered a wussy cam, especially for an LS2.
Go with a minimum of 230 intake duration, and just under .600 lift as a starting point
Old Apr 5, 2006 | 03:49 PM
Brabus2's Avatar
Thanks Bob & Nine Ball!
The cam was suggested by a big tuner shop in Indiana and used on their C6 TT setups...geewiz, cam selection is a tough biz for us newbies.
Okay...other recommendations by tuners I've contaced:
232/236 114 LSA
232/234 115 LSA
224/228 114 LSA
Anyone care to comment?
Cheers,
Richard
