Pulleys
Old Mar 19, 2006 | 10:43 PM
Cbrakllr's Avatar
Default Pulleys
Im going to be ordering a d1sc kit pretty soon. I want to run 11lbs. What size pulley do I need? Also when I call to order it do I tell them the pulley size I want? I new to superchargers so Im not quite sure. Thanks.
Old Mar 20, 2006 | 05:39 AM
EPP's Avatar
EPP
Unless you have a forged bottom end, I would not run 11 lbs of boost. I would stick to 8 psi. The ATI ProCharger D-1SC will normally come with a 4.5" blower pulley to get you 8 pounds of boost. If you have headers, exhaust, camshaft, heads, etc, these items have to be considered to get the amount of boost out of the blower that the customer desires. Headers and better flowing exhaust make the system more efficient, lowering the boost the blower will make, requiring a smaller blower pulley to spin the blower faster to raise the boost up. Camshafts will bleed off some boost through overlap, requiring a smaller pulley. Give me a call at 260 244-4808, I can get you a great price on an ATI ProCharger. Bob
Old Mar 20, 2006 | 05:00 PM
Cbrakllr's Avatar
All right thanks a lot man, I was going to run 11 lbs. but for now till I forge it i will prob run 8lbs like you said, My goal on stock motor is high 10's or low 11's. Could I do that with just 8 lbs.?
