View Poll Results: What should I do with my T/A for steet use??
Supercharge it and be happy
34
38.64%
Get a custom turbo with the most boost possible and big ass injectors
47
53.41%
Keep it the way it is, bro (Fuck You)
7
7.95%
Voters: 88. You may not vote on this poll
How far are you willing to boost?????
Old Mar 29, 2006 | 08:50 PM
TryingT/A's Avatar
that's good to hear spenser. I would like to stay away from converter boxes because my idle is touchy enough.(would also rather keep stock computer) During stops in Nuetral, the rpms will drop below optimal operating range for a second, but then kick back up again. This seems normal in a cammed car, it has never died on me but would not want the idle to worsen.
Would it be bad to have 1000bhp potential and only use about 700??
I'd opt for the big turbo and big injectors, but will they give me problems if i'm running low boost. One of the reasons i'm leaning toward a turbo over s/c: I would run around 8 lbs around town, like most s/c applications, and then turn it up when racing. Would having 76lb injectors if I only needed 42 be a bad thing, or will a good tune avoid most problems??? 3 bar map injectors run twice as much??Damn!
Old Mar 29, 2006 | 09:54 PM
pwrtrip75's Avatar
Originally Posted by EDawg
700 rwhp turbo done right=20k++
Is this sending it to NASA and on a govt budget? Yes you could easily do it for 20k, thats mailing your car to some place and getting it back done. But if you know how to use a wrench and read you can do it for less than half that easily.
Old Mar 29, 2006 | 10:14 PM
Spenser309's Avatar
uhh fyi changing boost levels with a supercharger involves changing your pulley's.
You shouldnt lose enough resolution to prevent the car from idling with 72lb injectors. Talk to Brains, his GF has a turbo camaro with 84lb injectors runing batch(all injectors at once) instead of sequential(goes with firing order) and he has got it to idle properly. The basics of "will this injector work" is if you can get the car to idle with the big injectors than it doesnt matter how much boost your running unless your maxing the injectors out. So the answer to your question is no it isnt bad to run at half injector potential.
Your injectors should not be described as 3bar injectors, or at least ive never heard them described that way. Your gonna need a GM 3 bar map sensor but ive never heard of such a thing as a 3 bar map injector, and it sounds really off and id ask them alot of questions before buying such a thing. 3 bar = 30#'s fyi.
You need to call RCEngineering and make sure that these injectors exist. #1 because i want to know. #2 because you need to know. lol.
You may want to change cams though, turbos allow you to run alot tamer cams.
Anywho that sounds like an amazing setup and i hope you get around to doing it.
Old Mar 30, 2006 | 12:18 AM
TryingT/A's Avatar
You're right, raising s/c boost only requires a pulley swap plus a shorter belt on hand, but not as easy as punching a few keys on the boost controller inside the car.
For some reason, I see more possibilities with a turbo setup, despite the $$$. A bolt on s/c setup used to be the wisest choice before all of these custom turbo setups were perfected. I'm glad to here that the almighty injector will still work at half potential as long as th idle is well tuned. My shop prefers the maf and t/b I use so it shouldn't be hard to tune but it seems they are all about sequential firing over batch. I might be wrong, but it seems that's the way they've gotten the best results. They incorporate an extra 7 gal fuel cell with 100 oct. that kicks in once the primary injectors are at 90% duty cycle.
"I would not mind having extra juice in my lunch box"
All preferences aside, i'm limited to what my shop deems fit, because they are the ones that will have to fix it, if anything goes wrong.
Speed inc. open house apr. 8th, but I will be too busy checking out the cars to be asking ?'s about my future mods.
Old Mar 31, 2006 | 04:06 AM
Schantin's Avatar
Originally Posted by TryingT/A
Thanks Schantin. definitely don't want to install and forget, always improvement to be made. I've ran into probs myself but well worth it. If something were to happen with the mods, speed inc. would fix it no problem, even no labor charges if it's a quick part install.
Your 'camaro looks awesome with the z06 rims!
Thank you. Always appreicate a compliment on the ride.
Old Apr 1, 2006 | 12:23 PM
BAD FNZ's Avatar
I'll be doing my custom TT Z06 project this spring/summer =D lookin for 600rwhp daily..
Old Apr 1, 2006 | 04:14 PM
Super Speed's Avatar
Thats a ver clean car man i'd go turbo with a built engine though!
Old Apr 1, 2006 | 09:39 PM
EDawg's Avatar
oh ****! i forgot this is ls1tech everyone is mechanic.
so... transmission, block, turbo kit " self built", fuel system, rearend, driveline, and whatever else i am forgeting is under 10k
 Michael S. Palmer
