Help with blower cam selection
Old Mar 26, 2006 | 02:13 AM
TrakDay's Avatar
Default Help with blower cam selection
I intend to go with a custom grind, but I am wondering what range I am looking at?
This is going in a Procharged 408/240 ET Head GTO
This car is primarily a weekend car and mostly track now, so big isn't going to bother me any!
I basically need it to help pull me through the big end while not giving up any mid range. And well with the new motor I think the low end will have plenty of power to get me away from the tree.
Any help is appreciated... Thanks as usual!
Old Mar 26, 2006 | 01:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Goal?
Old Mar 26, 2006 | 02:36 PM
TrakDay's Avatar
Goal?
750rwhp with the D1SC and no spray. Eventually I may upgrade to an F1R and look for more, but I think the D1SC and spray should hold me over until that time comes!
Old Mar 26, 2006 | 04:18 PM
FSUNole17's Avatar
PM me for a guy who knows his stuff about blower cams, i can give you his email/or phone # if you want to get in touch wiht him. He is VERY knowledgable and a great guy to deal with, he specd my cam and installed it and i am VERY happy with it.
Old Mar 26, 2006 | 06:43 PM
LS1Tech Co-Founder
Hmmm...
-raceweight?
-et and mph goal?
-slicks?
Old Mar 26, 2006 | 10:19 PM
TrakDay's Avatar
Hmmm...
-raceweight?
-et and mph goal?
-slicks?
~3800lbs
low low 10s in the high 130s
slicks eventually, for now I am running 15" Bogarts with MT ET DRs mounted. Then I will step up to a slick... still learning to tame the beast!
Old Mar 26, 2006 | 10:27 PM
LS1Tech Co-Founder
I made 730rwhp with a 230/236//115 cam, 17psi, and thru a T400 and a 9". I went 136mph with that combo fighting some belt issues.
After I fixed some belt issues (added strut brace), I went on to do 754rwhp with a fatter curve... due to 236/246/114 swap, hit 21 psi on the dyno.
I went 144mph after I dynoed 680rwhp in July. I was seeing about 18psi.
I'm thinking you should not have to go really crazy on the cam to hit say 138mph in the traps.
I was 3450 raceweight for those runs.
