Would I benefit from taking off....
Old Apr 10, 2006 | 04:50 PM
LSs1Power's Avatar
Originally Posted by KAOS
so adding fuel increases egts? so in order to make it spool faster ADD fuel and pull timing down low or what? i was always under the impression you took fuel out down low to help spool the turbo, i have a t74, same thing i guess, and its about the same, but i have a 1.00 AR housing. any info is great
The opposite... Adding fuel lower EGT. You should lean it out a little bit before boost comes and add a little bit timing to spool the turbo faster. Think of it as a N/A tune before the boost comes in. Just watch that KR and be careful. By peak TQ you should have the lowest timing possible in your table and then start to increase it again until redline.
Old Apr 10, 2006 | 06:12 PM
sr71's Avatar
you don't need a bullet muffler. try it with just a straight pipe first. the bullets I had on my car didn't quiet it any. they just killed all of that beautiful turbine whine. I don't run any muffs on the street now.
Old Apr 10, 2006 | 07:19 PM
frcefed98's Avatar
Originally Posted by sscam68
Cool! New Tranny is in!
I thought you had at least another week or so.
Nope its in Dave called me and asked for my address and two days later the freight truck was dumping off the tranny in the driveway
Sr71, i'll try it both ways sinces its easy enough to do
J
Old Apr 10, 2006 | 07:27 PM
bboyferal's Avatar
That's the ticket...
You're tempting me to go rip my bullet out right now.
Old Apr 10, 2006 | 08:52 PM
FastKat's Avatar
so you guys don't think a good header coating would help?
Old Apr 10, 2006 | 09:02 PM
frcefed98's Avatar
Sure it would, anytime a coating is used its a good thing....but I didn't do it because I didn't have the $$$$$$ when I put together my truck manifold kit. Maybe one of these days I'll get all the parts coated, right now pretty low on my priority....i'm just trying to get this thing to run right.
J
Old Apr 30, 2006 | 12:05 PM
Darren P's Avatar
as for a cutout I am running one on my car and it is still to quite
I woud not run any muffler bullet or other wise just run 3+ inch pipes out the back and it sounds really good
