NEED an Oil pump for Turbo set-up?
Parts so far-
Garret 60-1 turbo
Hallman MBC
50mm wastegate
HKS SSQV BOV
2.5" intercooler piping
Intercooler w/ 2.5" inlets
New custom bonnet
Bigger TB
Walbro LS1 intank fuel pump with hot wire kit -
Can you guys come up with anything else i will need for this as far as parts go?
This will be over the summer and if not i will only be gathering all the parts over the summer and fabing it up next winter- only going to run maybe 8 or 9 psi with a 75shot on top- should get me to around 330whp
And i will either keep my wet-kit or turn it into an intercooler spray bar
What about METH vs. Nitrous what do you suggest?
The turbo will be level or lower than the pan for sure so i will need a pump like the STS pump- correct
