G5X3 and boost, Answers within....
I'm thinking around 234/240 @ .050", or maybe 238/244.
Jim
My setup has been similar, but I am boosting higher and running through a T400 and a 9".
-matt
-matt
I love you guys that think a lower number on the boost guage means their engine has a better chance of surviving.
I would do a little more research into forced induction if you believe that.
In any case looks like your making more than enough power to have alot of fun.
Stay safe and enjoy!
you would run a stock cam and make ???psi on this setup and feel great about it ?? You sound like the guys who hate on big cams with any setup because you want to make that extra 13ft lbs before 2,500 rpms, then you lose to a big cammed car and use that extra duration for the excuse!! aHHH! I dont get it!
And congrats Nasty SS, thats good power no matter what cam it is.
Thanks
Honestly I run the small cam for several reasons, mostly because I can make a couple hundred passes a year with stock pushrods, rocker arms, light springs and dont have to worry about the valvetrain - just have to focus on the a/f and keeping detonation in check. Plus the car idlles at 600rpm and dont have to worry about it killing at a bad time. Thats the only reason I use such a small cam, no super secret small cam society bent on eliminating large cams here. Hard to argue that a big cam wont make more power, I just dont need the power at the moment.
My car is really nothing special or a 'ringer' LOL, I'm just using the power I have and its fairly light by forced induction standards. One day I'll step up to a little bigger cam and I'm sure the car will pick up, few other guys are building similar D1SC combos that are more geared towards drag racing like mine and they have 'real' blower cams and I'm sure they will run better then I do - then I can just say "hey you guys got big cams so you should be faster" Win/win for me
Jason
I havent swapped a ton of cams on an engine dyno so I am last guy to say what is 'best' for a centrifugal blower car or why. All I have done is run some sims with popular 'blower' grinds compared to what I have and the 20-30hp peak difference really isnt that big of a deal to me to start over and change the whole combo. Still goes back to the simple and reliable thing. This cam was in the car when I bought it and I worked around it and it proved to work well, thats why its still in here
If my car came with a G5X3 in it I probably would have gave it a shot with the blower, Clint made good power with a hotcam also so if you spend the time anything can work with a FI car, might not be the 'best' but it will work well and make power. I'm not running any heads up classes where I need the 'best' either, just havin fun.Shame you never spent the time with yours to get it 100% sorted out, would have been pretty easy to see just how much a larger 'blower' grind cam would have helped since our cars are similar..
For better or worse it should be noted that highest power is being made at 6,900 rpm's vs. the same power at 6,000. The is 13% difference in delta just based on rpm. Another 3% for SD tune. The port matched FAST, 90mm Tb and Meth were a good move too.
Advantages.
Very long rpm band.
High hp based on rpm alone. 113%
Disadvantages.
Huge wear, to the second power at a minimum, excluding friction.
Potentail blow by.
PVC
If the stock motor is run at the over 6,000 rpm range for any length of time...I will leave you with that. I would suggest you maintain your car very well.
Advantages.
Very long rpm band.
Disadvantages.
Potentail blow by.
PVC
Also, quit pulling numbers out of your ***, fool
