Would this be the equivalent of a T63?
Old Apr 12, 2006 | 12:12 AM
blackbird345's Avatar
Default Would this be the equivalent of a T63?
COMPRESSOR:
-Wheel- 63 Trim - 66.7 Inducer / 84.0 Major
-Housing- 100 Inlet / 60 Outlet - 0.70 A/R
TURBINE:
-Wheel- 76 Trim - 74.2 Major / 64.7 Exducer
-Housing- T04 inlet / 65.75 outlet - 0.81, 0.96, 1.15 A/R
650-700 PS Output
Trim: 63T
A/R: 0.81
Flange Type: T04 Flange
Wastegate Type: External
Compressor outlet V-band flange
Assembled and balanced in the USA
Compatible with all cars utilizing a custom turbo setup
Lifetime warranty from manufacturer defects
Old Apr 12, 2006 | 02:06 PM
RealQuick's Avatar
Originally Posted by blackbird345
COMPRESSOR:
TURBINE:
650-700 PS Output
Trim: 63T
A/R: 0.81
Usually the compr. wheel describes the turbo, so in your example it would be like a T67 (~66.7mm).
Old Apr 12, 2006 | 11:12 PM
So basically a T76 is just a turbo with a 76 mm intake on the compressor side?
