header fab advice needed
Old Apr 13, 2006 | 06:02 PM
AKAFRED's Avatar
Default header fab advice needed
is there any certin order the primaries on a header should go into the collector. i relize that it would be ok in any order but is there a certin order that would be better.
Old Apr 13, 2006 | 06:35 PM
Boostaholic's Avatar
Whatever works out best for your header design is what I would say, easy way to fab it up is with some foam tubing and coat hangers bent inside the tubing to route the primaries to your collector
Old Apr 13, 2006 | 07:24 PM
Race-Prep's Avatar
Suspended Sponsor
As long as you are not building a Tri-Y design, it really makes no diffrence, I would worry about the length and diameter much more! I worked for a header manufacturer for a few years doing the R&D and I have seen this first hand.
-Bryan
Old Apr 14, 2006 | 06:51 AM
AKAFRED's Avatar
i will be using 1 3/4" primaries as far as i can see the end primaries will be the same but the middle 2 might be shorter unless i can add some length some how.
Old Apr 14, 2006 | 07:03 AM
Lasershop's Avatar
I built a set and basically did my best to make them equal length. Only so much you can do when they are shorter turbo headers and your space is limited. More concerned with fit and finish. Try to keep in mind that so many guys are making big power with stock manifolds. Helps things to be not so critical in design.
