Thoughts on this wastegate?
Old Apr 17, 2006 | 10:00 PM
80superbu's Avatar
Default Thoughts on this wastegate?
Looking for you thoughts on this wastegate for my GT42 setup
http://www.jgstools.com/turbo/50bmg.html
Introducing our latest wastegate, the JGS 50BMG!
Product Features-
* Silicone O-ring and piston type actuator- For long cycle life and easy track side repair if needed.
* 2" V-band connections- For 2" OD pipes and tubing (1.875" ID). Includes clamps and flanges
* 50mm SS valve- Big enough for even the largest turbochargers holding low boost
* All CNC machined construction- For style and excellent tolerances
* Externally clock able pressure ports- For ease of installation
* 3 Series SS valve housing- For excellent corrosion resistance
* Cast iron valve guide- For very high exhaust temps and anti-seizing properties
(pre-anodized unit shown for detail)
Made in the USA, not another cheaply made imported copy!
Engineered, Tested, Machined, and Assembled here at JGS Precision Turbo.
Built to survive over 1 million full cycles on a single set of o rings at boost pressures of 40-50+ps
About $349
Old Apr 18, 2006 | 09:31 AM
DrTurbo's Avatar
LS1TECH Sponsor
Call Jose, they are now a distributor for that gate.
Old Apr 18, 2006 | 12:52 PM
80superbu's Avatar
Good deal!
Old Apr 19, 2006 | 12:43 AM
TwoFast4Lv's Avatar
Damn they are just down the cost to!
I am guessing Jose would like the JGS400's for twins
Old Apr 19, 2006 | 09:02 AM
DrTurbo's Avatar
LS1TECH Sponsor
Jose ordered several different ones already. I will get to see them myself this weekend when they arrive at the shop.
Old Apr 19, 2006 | 02:25 PM
Stupid Boost's Avatar
I ordered one from them. They are suppose to be bad pieces. I will see.
