Help Please fallin boost
Old Apr 20, 2006 | 06:24 PM
mattslightning's Avatar
Question Help Please fallin boost
I just in stalled my sts kit. It is a T-67 and I have added an obx fmic. My problem is that I am only seein like 4 lbs of boost on my gauge and i know thw gauge is some what right cause on the dyno you can see the car pullin like a monster and then at about 4500 rpms the boost drops to 3 lbs. I put a tee in series with the wastegate to watch my pressure back at the turbo and it is showing 9 lbs which is what I am wanting. Anyone have any ideas?
Oh I forgot to add that I have gone threw every clamp and coupling to make sure they are tight and look sealed
Old Apr 20, 2006 | 08:02 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You have to boost reference the wastegate to the intake instead of the turbo after a fmic install. The drop in charge temperature and the added flow restriction of the intercooler combine to produce lower boost readings after it than before.
Old Apr 20, 2006 | 11:25 PM
now that makes since I will give that a try
Old Apr 21, 2006 | 06:29 PM
gametech's Avatar
BTW, I was a little nervous about trusting rubber vacuum line for runs that long, so I used mostly steel hardline instead.
Old Apr 21, 2006 | 07:19 PM
Boostaholic's Avatar
You should also watch out for cheap wastegate lines, we blew up a car last year because the wastegate line melted right at the gate and it snapped shut mid run.
