knock sensor tray...under intake and valve cover question
Old Apr 24, 2006 | 11:03 PM
SINISTER's Avatar
Default knock sensor tray...under intake and valve cover question
ok turbo biys
when i installed my mti iron block buddy said to put this i beleiev z06 metal tray where the knock sensors go down in under the intake...
tray looks awsome but one question it has a valve/tube comming out the front of it...know i know this would be a breather tube???where should i be running this into?? catch can?? valve cover??
lil help im lost when it come to vacume and such
valve covers...right now i have the speed inch breather where my oil cap goes..now this is great but i have seen you big boys with the vavle covers with the an fitting comming out the top and going where???i know this is to pull pressure out of the crank case do you have these lines going to a catch can also??
Old Apr 25, 2006 | 11:42 AM
SINISTER's Avatar
anyone?????
Old Apr 25, 2006 | 11:47 AM
smokinHawk's Avatar
that is the valley cover, and im guessing what your talking about is te pcv tube.
you can hook it up like the regular pcv system as you would from your valve covers, for FI you might use a catch can then route it back to the intake port after the TB.
