Info on Effects of Water/Alky Injection
Old Apr 27, 2006 | 01:15 PM
Gold Phoenix's Avatar
Default Info on Effects of Water/Alky Injection
I want to know how much of a difference it makes on FI. I am building a 402cid with 9.25:1CR, large cam, and a F1R. I was told by a shop that with the largest pulley I could see 20psi of boost at 6000rpm. I am attempting to run on pump gas with this much boost. I want to know how much water/alky will lower intake temps or EGTs. I am trying to ask only guys that have done something like this.
Old Apr 27, 2006 | 03:47 PM
Silver02Z28's Avatar
The methanol also fattens up the mixture a bit. You could see about 40 to 50 degrees F in intake charge cooling with water/methanol.
Old Apr 27, 2006 | 04:04 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default .....
search cablebandits threads he had some good research on this. Note his results were also based on the nozzle sizing and pump flow and pressure.
