question about your hot pipes
Old May 1, 2006 | 03:01 PM
markp03's Avatar
Default question about your hot pipes
Alright guys off of your truck manifolds what size tubing did you go to the turbo with? 2.5"? 3"? also what thickness of s/s did you use? .049?
also what is the flange called the one i need to bolt up to my truck manifolds.
i am just wondering what i need to buy to start fabing up my system.
I am using truck exhaust manifolds with a PT76gts turbo
Old May 1, 2006 | 04:42 PM
Josh@KY-Turbo's Avatar
Here are the part numbers your the 6.0L manifold flanges from Stainless Works:
3/8" s/s flange
[FLNGCDH]
3/8" s/s flange
[FLNGCPH]
Old May 1, 2006 | 05:31 PM
markp03's Avatar
ok cool do most of you guys use 2.5 " or 3" piping off of the manifold?
Old May 1, 2006 | 05:48 PM
2001WS6Vert's Avatar
2.5". I wouldn't think there would be any advantage with 3". It would be larger than the manifolds and then shrink way down at the merge to the turbo.
Old May 1, 2006 | 06:02 PM
2.5 for sure. No need for anything larger on a street style setup.
Old May 2, 2006 | 06:50 AM
smokinHawk's Avatar
use .065 wall tubing.
i used 2.5" to the turbo, a 2" wastegate piping, and a 4" downpiping.
