Turbo N2O setup
Old May 6, 2006 | 04:08 AM
HAMRHEAD's Avatar
Default Turbo N2O setup
For adding N2O to a single big turbo set up would you go with a DP or 90mm power ring set up? I already have a TNT F1 kit from my previous set up but I could go TNT DP if needed.
Old May 6, 2006 | 08:00 AM
anarchy99's Avatar
90 mm Power ring!!!!! I was in the same boat as you as far as having stuff lying around to use, that's why I ended up using it. Hindsite being 20/20, I would have not put the directport onto the car on top of the twin turbos because it just makes it too complicated and hard to get to ****!!!!! Looks cool, but making it practical will spend all your tax free money... Just like it did mine!
Old May 6, 2006 | 08:45 AM
HAMRHEAD's Avatar
DP does look pretty! I was thinking the power ring too since I may end at some time use 16 injectors and if there were a DP system then it just get all clustered up! Thanks for the input.
Old May 6, 2006 | 12:46 PM
HAMRHEAD's Avatar
Any other opinions?
