STS Boost Question
Old May 13, 2006 | 09:01 PM
vandal0-0's Avatar
Default STS Boost Question
I have a 408 with the t-60 and installed a manual boost control.You can close the valve all the way and it still makes 7lb.We even removed it completely and plugged the hole in the turbo going to the wastegate and it did the same.Any suggestions.
Old May 13, 2006 | 09:22 PM
bboyferal's Avatar
You must have a 7# rating on the wastegate spring.
Old May 13, 2006 | 09:34 PM
ddnspider's Avatar
maybe its just me but isnt that turbo hella small for that CI?if u took off the wastegate and it only made 7 psi your choking the **** out of your turbo/motor.is this a stick or an auto?
Old May 13, 2006 | 09:35 PM
Frost's Avatar
Holy ****! I was worried about my 76 on a 402...
Old May 14, 2006 | 11:00 PM
jcfreak's Avatar
I would go back and check the install instructions and make sure you have everything hooked up properly.
Old May 15, 2006 | 12:00 AM
ddnspider's Avatar
ummmm at 7 psi your pressure ratio is ~1.47.if you look at the air comsumption chart for a 408 its approximately 66lbs/min of air.now take a look at a T67 turbo which is quite a bit bigger than his T60....@66lb/min and a pressure ratio of 1.47 hes no where close to being on the chart in the efficiency range....so its even worse with the T60....really mismatched setup is the problem
