hand ported TB under boost....
Old May 14, 2006 | 02:52 AM
2002/Black/SS's Avatar
Default hand ported TB under boost....
i handed ported my TB and filled in the upper part with epoxy, will it hold under boost? or should i not take a chance and just buy a real ported one, or just another stocker and port it just without using epoxy? (i have a hi-flow kit on order)
Old May 14, 2006 | 03:10 AM
rubber duck's Avatar
Did you fill it because you put a hole in it?
Old May 14, 2006 | 03:22 AM
i filled it and drilled 2 1/4 inch holes in it
Old May 14, 2006 | 10:27 AM
MIGHTYMOUSE's Avatar
mines been like that for years
Old May 15, 2006 | 12:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mine has been like that since 2001.
Old May 15, 2006 | 01:23 PM
kp's Avatar
kp
mine was ported/epoxied in 1999 and is still going..
Old May 16, 2006 | 02:48 AM
Mike 01WS6's Avatar
Ported when car was basically stock and still going strong under boost. Ran anywhere from 20 deg F to over 100 deg F. Dry and humid conditions. You'll be fine, just don't use junk epoxy.
