Mike Brown's Turbo Build Pics
Old 05-17-2006, 05:16 PM
  #41
SPANKY LS1's Avatar
Old 05-17-2006, 05:17 PM
  #42
frcefed98's Avatar
NICE! That'll be awesome to have....but what's considered interesting?
J
Old 05-17-2006, 05:25 PM
  #43
NA$TY-TA's Avatar
Okay I will Brains to set it up. The FI mods can all have access to it.
John sent ya a PM.
Old 05-17-2006, 07:21 PM
  #44
TwnTrboCE's Avatar
Default Thanks Everyone
fash00, I'm shifting it at 7,000 and it runs out the back at 7,400+ Still hydro cam. Both the turbos spool up on the line about the same. The 91 comes in a little slower. Which has been a good thing on the radials.
F8LWS6, I'm running a BMR k-member with a poly mount on the driver side and I custom made a solid on the passenger.
Onfire, Moroso DS-2 is right. Straight as an arrow at the track.
PSJ, I ran a big K+N filter on the 88. None on the 91. The Tilton has been working perfectly.
SPANKYLS1, Thanks for posting the spy photos.
Old 05-17-2006, 07:41 PM
  #45
NA$TY-TA's Avatar
Lovin it...... You log fuel milage for fun???
Old 05-17-2006, 08:04 PM
  #46
gillbot's Avatar
Stock bottom end?
Edit, Nevermind, I see the details now.......
Old 05-17-2006, 09:58 PM
  #47
Birdie2000's Avatar
How's that work with the 1 solid and 1 poly motor mount? I've always wondered about doing that with my BMR K-member for a little added rigidity.
Old 05-18-2006, 09:49 AM
  #48
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Mike: So you run a poly on the driver's side. So does your motor torque up a little? If so, do you have the body/ frame clearanced on that side to allow for that? And/ or did you have to clearance that side in general just to fit the turbo and the filter? Where your 88mm passes with the filter on? Any recollection on the dimensions, ie. 5" x 10' or 14" long?
Thank!
Old 05-18-2006, 10:20 AM
  #49
smokinHawk's Avatar
hmm i wonder who toook those
Old 05-18-2006, 10:28 AM
  #50
LS1Tech Co-Founder
Nine Ball's Avatar
Very nice setup, I like that A2W intercooler too. Where do you have the cooling water tank located, in the trunk?
Did you have to modify/relocate the pass side engine mount on that k-member to clear the downpipe?
Old 05-18-2006, 10:39 AM
  #51
smokinHawk's Avatar
water tank is in the trunk, to the side i believe
yes he said he made his own custom solid motor mount to get the 5" downpipe through there.
Old 05-18-2006, 01:03 PM
  #52
stang90gt50's Avatar
What size cam do you guys have in that thing to spin it up to 7500rpm?
Old 05-18-2006, 03:35 PM
  #53
SSU'S Vice Mod
sb427f-car's Avatar
Impressive looking. Clean with minimal cutting too.
Old 05-18-2006, 05:18 PM
  #54
Boo"SS"t's Avatar
Yes, "impressive" is the word to describe that set-up, especially when you're looking at it person. Clean and very well laid-out. Just imagine what their (OhioBoys) race car replacement (camaro) would look like when it's finished.
Old 05-18-2006, 05:48 PM
  #55
TwnTrboCE's Avatar
Thank!
First. I wasn't thinking the other night. It is a Pro-Fab K-member. Everything else is BMR.
Motor does still move a little. The way the solid mount is designed allows it. I did have the bottom pinch weld area notched so the filter would slide on the turbo and allow movement. With the 91 I had to do a bit more notching. I still have the filter and cam get meas. if you want.
The water tank is in the left rear corner. Battery and overflow is in the spare tire area. Still have room to put the T-tops back there when cruisin.
The cam. Well I'd have to kill ya.
You guys think it looks good now. Wait till I post the pics after the new motor goes in.
Old 05-18-2006, 06:42 PM
  #56
Kevin 276's Avatar
Mike awesome job, I can't wait to see it in person...
Old 05-18-2006, 10:01 PM
  #57
Suspended Sponsor
Leo@GMRSPEED's Avatar
Ok, I can now tell the city of Cleveland where the missing sewer pipe dissappeared to, that DP is huge... nice setup man, has proven nicely for ya, will be cool to see the new setup.
Old 05-27-2006, 09:22 PM
  #58
WdClaSS99's Avatar
Thumbs up
Nice...
Old 08-04-2006, 09:38 AM
  #59
SINISTER's Avatar
hey man im getting ready to finish up my new set up and my turbo hangs just a lil to low for gravity feed...
im gonna have to use a pump to get it back up into the pan..
my question to you is when i mount the oil pump like say where your is in the pics...do you have it going from the pump then directly into the pan
or into a oil holding unit then it gravity feeds down into the pan??
tahnks
Quick Reply: Mike Brown's Turbo Build Pics
