Timing question...
Old May 25, 2006 | 11:41 PM
mulot30th's Avatar
Default Timing question...
We built a LS1 347ci forged with 8.5-1 compression ratio.
When running under boost (okay .. only 6-7# of boost) we got the timing up to 32degree advance at 5000-6000 and still doesn't get any Knock retard... on pump gaz.
I really wonder at which point we will hit some knock with our setup!!!!
Can this be normal????
Old May 26, 2006 | 03:49 PM
mulot30th's Avatar
So nobody can answer this one?!
Will I blow a gasket before getting any KR????
Old May 26, 2006 | 04:17 PM
BoostedWS7's Avatar
i would say u are right around the point that you will start to see knock. ofcourse, how rich/lean you are is also a factor though.
you'll see knock b4 the gasket goes...def..lol
Old May 26, 2006 | 04:59 PM
white2001s10's Avatar
It depends on the heat factor. Loading the engine down out on the road in high gear for a long time period could very well push it into knock and detonation. How long it lasts before that point depends on heat management.
Old May 26, 2006 | 05:02 PM
mulot30th's Avatar
Okay... so we will see where it will see knock and back up!
Was asking if I were about to run into troubles before seeing any KR
