rear mount build up questions
-what size pipe (cold side) comes with the sts kit? Ive heard 2 1/4 but I was thinking of going with 2.5" for a system running 8psi. Downsides to 2.5"?
-does anyone have info on what size fittings are needed for everything. I know where to buy the stuff but i'd like to keep it similar to the sts as possible. so:
-feed line size/fittings, -return line size/fittings, -what size checkvalves (turbo one vs pcv one or they same size?), -tubing size for wastegate/bov
i was hoping to just find a write up somewhere or instructions but no luck. It just makes it easier this way than trying to picture everything. And they shoudl work on my mocal pump right? thanks
What do you mean "what size fittings"?
