Boost reference (fuel regulator) for STS...good setup?
The biggest thing I saw was that the fuel is adding long term enrichment (goes back to needing to create a better part throttle tune). Anyhow, the car was initially at 371RWHP. The HP dropped off at 4700RPM and the entire curve was a bit shaky looking. I turned the fuel limit off with HP tuners and instantly went up 50RWHP to 426. The HP curve was more consistent and was actually still climbing at the 6K pre-determined "cutoff" point. A/F was measured at a max of 12.0 to 1 on the dyno wideband, though only at 10.6 to 1 on my AEM wideband. I have 42lb injectors, but they are cycling about 17.4 at 4500RPM and above....so they are working hard in the upper RPM range.
So....verdict is the injectors are having a problem fighting against the boost pressure to deliver the juice to the engine. I was going to add a fuel regulator with a boost reference. Any good suggestions on a setup for this? Any work with the stock fuel rails or will I need to change those out too?
I figured this Q could go in either FI or fuel section....but I'm asking specifically as it pertains to my turbo setup.
Any input would be much appreciated. Thanks.
you will need to remove the stock regulator so while your in there may as well upgrade your pump and kill 2 birds with one stone.
Just the stock fpr may even give you some boost referenced kick on the fuel pressure. When I get mine on the road, I'll be checking on how much more fuel pressure I get under boost. I'm running a '97 vette setup on my '98 Camaro. (previously a v6 car so it already had the return line plumbed all the way to the tank...)
