LS7 build up
...................TURBO ALL THE WAY...1 or 2 is cool.. if u got the bread..go for 2 of 'em.....
oh yeah I vote for turbos straight from HONDA!!!
just joking
With the 6-bolt block, strap a F2 or F2-R on it and call it done
Keith
He's not looking to make 1800whp or anything. I'm sure a LS7 block could hold 1200whp?
The LS7 block does have the 4.125" bore, but otherwise is much closer to normal LS2 specs.
The Warhawk is an aftermarket item that apperas to offer the strength of the C5R at a lower cost.
Oh let me add to this just like slowhawk said the factory ls7 sleeves are not very strong and should not be used for forced induction so either resleeve the block or put the aps kit on it and run fairly low boost so your rwhp does not go over 700 rwhp and you should be fine with the factory sleeves. Katech has a lot of experience with the factory ls7 sleeves and have not had any fail, but their using them NA with power levels up to around 600 rwhp.
I suggest you shoot this dude a pm bro
Sorry I see that you did in fact pm him! good decision
