Power differance between mid frame and large frame turbos???
Old Jun 5, 2006 | 08:07 AM
00turboT/A's Avatar
Default Power differance between mid frame and large frame turbos???
Like the title says I was wondering if there is a differance in power or power curve depending on the turbo frame size as long as its say a 76MM midframe compared to a 76MM large frame. If not whats the advantages of the larger frame turbos??? Any responses would be great thanks guys.
Old Jun 6, 2006 | 05:46 PM
00turboT/A's Avatar
NO body?????
Old Jun 6, 2006 | 05:56 PM
eviltwins's Avatar
Here's what it brakes down to in my understanding.
Small frame = T4 compressor, T4 exhaust (IE, PT76-GTS)
Mid frame = T4 compressor, T6 exhaust (IE, mid frame T76 with a F-trim turbine, PT88 T6 housing)
Large frame = T6 compressor, T6 exhaust (IE, PT91.5, GT47-88, PT101, etc)
So the only "large frame" 76mm turbo would be like a few cheater turbos PTE/ITS offer with a 94-ish mm wheel necked down with a 76mm inlet reducer. Obviously the result is more power with more lag, just like going bigger on any turbo.
Old Jun 9, 2006 | 12:35 AM
00turboT/A's Avatar
Thank you sir makes since. Thats just what I wanted to know
