wtf is up w/this...
Old Jun 6, 2006 | 06:15 PM
Assassin's Avatar
Default wtf is up w/this...
story..... so I get 42lb injectors about a year before going turbo because I knew I'd be boosted..... fast forward and here I am w/ a 2bar sd tune running alcy, my ve table #'s are lower in the alcy/boost range than it was NA, does this mean I could have stayed w/the stock injectors going the same route w/the alcy? motor is stock besides valvesprings and pushrods, I'm running 11.2afr in boost and 12.9afr before 95kpa, wondering if I need to spend the extra $$ on my next turbo ls1 build or not... thanks for any of your experiences
Old Jun 7, 2006 | 04:38 AM
EPP's Avatar
EPP
At the very least, 42lb injectors are indeed needed. Bob
Old Jun 7, 2006 | 05:49 AM
Bankz27's Avatar
I agree with you as well. Its better to have enough fuel then not enough.
Old Jun 7, 2006 | 10:45 AM
markp03's Avatar
yea by no means did you go too big on injectors hehe....i have 60 pounders and when my car is running i will only be on 8-9 pounds of boost.
