twins on the truck are almost done
Old Jun 12, 2006 | 10:23 AM
ram09's Avatar
What intake are you going to go with when you ditch the truck intake? If it is a LS6 intake, then dont bother!! The truck intake makes more power than a LS6 intake, its been proven by several car mags. If it is the FAST Intake go for it.
Old Jun 12, 2006 | 10:25 AM
ABeasst's Avatar
he is going to switch to a carb intake.
Old Jun 12, 2006 | 10:35 AM
CrawlinWS6's Avatar
Import Patrol
Damn! That is def. one bad *** truck!
Old Jun 25, 2006 | 04:49 PM
red90cobra's Avatar
parish what size pipeing are you manifolds
Old Jun 25, 2006 | 05:07 PM
parish8's Avatar
single digit dreamer
the intercooler turned out great. mike from sublime, a local shop welded them together.
before
after
the header pipes are 2.5" pipe trade and 1.5" pipe trade size. 1.5" is really around 1 5/8" inside.
Old Jun 25, 2006 | 05:25 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Lookin' bad as usual. That truck is sick...Period.
Old Jun 25, 2006 | 09:15 PM
NA$TY-TA's Avatar
Looking Bad *** Parish......................
Kyle
Old Jun 25, 2006 | 09:18 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
I also have always wanted to do something with twins....
Old Jun 25, 2006 | 10:34 PM
Project GatTagO's Avatar
How big are the pipes that you used for primary pipes and the logs?
Andrew
Old Jun 26, 2006 | 01:30 AM
red90cobra's Avatar
Andrew
so the log itself I believe is 2.5 and the primarys are 1.5.
parish is there any reason you used 1.5? why not bigger? are you using the 2.5 and the 1.5 primarys for velocity? can you post some pics of the log
thanks.
Srun
Old Jun 26, 2006 | 01:33 AM
red90cobra's Avatar
intercooler looks awesome
Old Jun 26, 2006 | 01:48 AM
  #32
oodahss's Avatar
the headers, exhaust, and all the plumbing looks great. nice job at tucking everything in there and still having it look clean as ****. great truck man have fun at the track.
Old Jun 26, 2006 | 05:19 AM
  #33
parish8's Avatar
thanks guys.
the 1.5" "trade size" is really 1-5/8" inside diameter and it matches the port size on the heads. there are lots of pics >> http://www.neufamily.org/images/turb...lery/index.htm
Old Jul 7, 2006 | 06:14 PM
  #34
chris01hd's Avatar
I was wondering what fuel injectors you are using, Im trying to put 42LBers in my truck but cant find adapters for the truck.
Old Jul 8, 2006 | 05:34 PM
  #35
parish8's Avatar
96lb units, you can get 42's that will plug right in but to go bigger than that you need to make some mods. the big ones are prety easy to get in there. solder on some new conectors, shim up the fuel rails and tweak the crosover is it.
Old Jul 8, 2006 | 07:02 PM
  #36
xfactor_pitbulls's Avatar
The setup looks great, and I guess log manifolds can make power. Curious though, while dispelling all the exhaust, why didnt you sweep the primaries forward to help creating venturi for exhaust flow? Do you feel like its insignificant? Not being a wise ***, just trying to understand.
Brandon
Old Jul 8, 2006 | 09:12 PM
  #37
parish8's Avatar
Brandon
this is my first attempt at fabing anything up like this and i am going with the easiest design i can. a simple log is as easy as it gets. sweeping the forward would hit the plug wires. if i were to attempt to make it any better than what i have now i would go for shortly style headers.
Old Jul 8, 2006 | 09:20 PM
  #38
unit213's Avatar
Administrator
I love the aggressive look of the turbo placement. Looks real nice!
