Dyno tomorrow morning!!!!!
I'm using the Cometics without any problems at 17lbs.
What was Speed's secret to keeping the car from blowing off the tires on the dyno. We can't get mine to stick to the dyno after about 810 - best was 875 smoking the tires? We have tried 2 friends in the back end, tying down the wheelie bars. Any suggestions - except rolling the car almost off the back side of dyno - we are not that crazy about dyno numbers.
David
Well I checked the tire pressure when I got back to the shop. They were at 16 psi. Jim also had four straps on the rear end. I was changing the coils and tripped over one of the straps on the front! Holy Sh--! were they tight! I think my car is two inches longer now!
David
Congrats Andy its been a long time coming,gladto see only minor problems on such a wild setup
http://www.siouxfallsracing.com/Foru...ic.php?t=31832
I'm really happy. I have to thank Tom, Jim, Dan and Larry. They talked me into this set up and I think it's going to be alot of fun. Tom is the best guy in our business to work with. Went I get the new gaskets in I'll bring it back and turn up the wick!
Congrats again. Are these the new Cometics that have some sort of fire ring for nitrous?
C16. My car is a 2002 bought in 2001. It has 7000 miles on it. I don't get to drive it that much. I would never run pump gas, too much crap being sold. I'm sure I don't need that much octane with the 18lbs of boost, but I have two 55 gallon drums that I need to start burning.
I'll end up using 110 on the street and C16 at the track.
Good point, I was at 148mph @ 7350rpm.
On the track I've hit 16 lbs and 8100 rpm's with no problems.
Good luck that thing should be well into the 8's on 18 lbs of boost. I'd say 8.50's or so if you're at a pig weight like mine ~3450 race.
I'm going with the mls, Speed inc has them in stock. I want to drive it this weekend!
