STS/ Rear mount owners...In here now!
https://ls1tech.com/forums/forced-induction/529173-switched-headers-manifolds-rear-mount-turbo-results-inside.html
https://ls1tech.com/forums/showthread.php?t=529173
how does a 2 step work. (i'm new to some of this)
and in your signature what is the difference where you talk about the trim and the 2 different dyno numbers?
also my STS kit will be here in about 1 1/2weeks and I have kooks longtube headers 1 3/4 and catless kooks y-pipe, otherwise stock.
did install 3.73 gears...
i will see how things go
here is the link i promised
http://forums.corvetteforum.com/show....php?t=1413757
thank chris
yo longrange4u
The 60 trim vs 67 trim are different turbo sizes... T-60 vs T-67
With your 3.73 gears... I would be very careful not to blow your back end apart... I see a 12 bolt or 9" in your future. I run a Moser 9" from Driveline solutions in mine.
ok gotcha about the trims.. i for some reason was thinking it was somethin else.
hopefully the 10 bolt will hold up, i haven't abused it and don't plan on it. but torque can do things...
what tracktimes did you run with the 60 trim turbo?
