twin turbo questions
Old Jun 16, 2006 | 10:31 AM
AKAFRED's Avatar
Default twin turbo questions
ok i am building a twin turbo 383 lt1
the turbos are
Innovative 60-1 hifi, 0.81 ar p trim exhaust, big shaft, heavy duty backing plate, and polished compressor housing
what kind of psi should i shoot for max with these before they loose effeciency?
will they go to 20psi?
also
where could i get a rebuild kit for these so i could freshen them up before running them? also what would said rebuild kit go for???
Old Jun 16, 2006 | 11:56 AM
DrTurbo's Avatar
LS1TECH Sponsor
I would have them freshend up and zero balanced. You might want to talk to Jose, he rebuilds these units in his sleep...lol. A rebuild kit from ITS direct would be pretty expensive.
As for 20psi, you should be able to reach that with a basic built LT1.
Old Jun 16, 2006 | 12:19 PM
AKAFRED's Avatar
wouldnt these be balanced allready? i just dont want to dump a boat load into redoing these.. i might as well scrap them and buy new....
also if i were to ship these to the states i would have to pay brokerage on them when they come back if i want them insured.... no thanks.
Old Jun 17, 2006 | 01:38 PM
turtle and the hare's Avatar
Default STS-South Texas
In most cases, it is better to just get new ones. Regarding cranking to 20 psi, it depends on multiple variables and parameters setforth by your motor, diameter of piping, intake, etc, etc.
If you have any questions, i will try my best to help
andy
turtle and the hare
STS-South Texas
281 772 7965
Old Jun 17, 2006 | 05:08 PM
DrTurbo's Avatar
LS1TECH Sponsor
They "should" be balanced. You can order the rebuild kits seperate from Jose if you want. He can take care of it. I had no idea you were outside the country....
Old Jun 18, 2006 | 06:37 PM
AKAFRED's Avatar
i am in canada... i have no problem dealing in the states but the problem is these turbos new arent that cheap and i wouldn't want the ups guy loosing them on the way back in their new state lol
also the guy i got them off said they only has 10 passes on them and i guess every one would say that..
how much shaft play should these have? i probably have 10 thou up and down and 5 in and out
