BOV before or after maf?
Old Jul 6, 2006 | 03:06 PM
02Vortech's Avatar
Default BOV before or after maf?
as the title states
Old Jul 6, 2006 | 03:24 PM
SUPER DAVES Z's Avatar
before. it will run really rich when you let off the throttle otherwise.
Old Jul 6, 2006 | 03:34 PM
bowtieman81's Avatar
Yep, you want whatever amount of air goes thru the MAF to go into the engine, otherwise it will throw things off.
Old Jul 6, 2006 | 03:44 PM
02Vortech's Avatar
so this means it goes before the maf..... meaing that it doesnt go inbetween the TB and the maf
Old Jul 6, 2006 | 03:51 PM
777's Avatar
777
correct, otherwise you have a 'vacuum leak' which is not good. As stated alreay everything that passes the maf needs to go into the engine, otherwise the readings that maf gave are incorrect and will cause all kinds of stuff to happen, none of it being good.
Old Jul 6, 2006 | 04:19 PM
(air)--->bov--->maf--->throttle
