meth pump and mounting??
Old Jul 8, 2006 | 01:35 PM
greentahoe's Avatar
Default meth pump and mounting??
Ive had my Snow kit for a couple years and now my 3rd pump has started to leak where the plastic cap and metal body meet. This is the same leak that has developed on my previous 2 pumps. This pump was even coated with silicone there to prevent this. What kind of pumps are you guys using and where are you getting them from? Im going to replace my tubing (as that leaked and had to coated with silicone as well and looks like crap) with rubber tubing and vacuum fittings with the push on barbs. Also what position are you guys mounting the pump? Mine is horizontal and leaks are the bottom. Should I mount the new one vertically if possible??
