700+rwhp - LS2 vs. LS6
Old Jul 10, 2006 | 08:33 PM
01Bird_of_Prey's Avatar
Default 700+rwhp - LS2 vs. LS6
Currently I make over 700 rwhp w/ stock non-ported LS6 and ported TB. I was given a LS2 intake - I'm wondering if it's worth the money for the 90 mm TB to get any gain. I run 13psi and AFR 225's and its a 410 ci. I plan on running 16psi as soon as someone gets BS3 and stock guages working, which no one seems to be doing.
Old Jul 10, 2006 | 09:12 PM
gator's 99TA's Avatar
i say the 90mm tb/intake will help out more based on flow numbers and pure plenum size difference.
Old Jul 10, 2006 | 09:54 PM
longrange4u's Avatar
Or sell both... buy Sheet metal intake and Victor Jr.
Good post... I havent seen any side by side flow numbers of the LS1, LS6, LS2, LS7, Victor Jr intakes. Would be good if anyone had the numbers though!
Old Jul 10, 2006 | 10:36 PM
FormulaFire's Avatar
Stick w/ the ls6.. it's proven
Old Jul 11, 2006 | 12:45 AM
BIG BAD BLACKSS's Avatar
Is everyone with the "stock" throttle body running a stock LS6 t-body on an LS6 intake? Or is it an LS1 t-body on a LS6 intake? Everyone says "stock" but im not sure which they mean?
Old Jul 11, 2006 | 10:27 AM
NoGo's Avatar
Stick with the LS6.
I did a bunch of testing with the LS2 intake and different throttle bodies on a supercharged vette 346ci at 15 psi (711 HP). Guess which one made the most HP........LS6, ported TB.
The only thing the LS2 intake and larger TB accomplished was the 'drive through the garage door' syndrome.
-Kevin
Old Jul 11, 2006 | 10:56 PM
LANCE ATKINSON's Avatar
did u port the ls2 intake?
Old Jul 11, 2006 | 10:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My friend is doing an LS2 intake, can you use aftermarket fuel rails with it with regular injectors?
Old Jul 12, 2006 | 01:09 AM
Got Me SOM's Avatar
I don't believe the ls2 intake will give you any gains because you'll lose air velocity.
sell it.
Old Jul 12, 2006 | 10:23 PM
ujslost2's Avatar
If u lose that much velocity by going to an ls2 intake sounds like u need to buy a procharger!!
Old Jul 12, 2006 | 10:39 PM
05_GTO's Avatar
Stay with the LS6.
Old Jul 12, 2006 | 11:04 PM
Drewstein's Avatar
Stay with the LS6
Old Jul 13, 2006 | 09:15 AM
Rey Kirkman's Avatar
The consensus seems to be that the LS6 manifold is superior to the LS2 manifold; and that the 90mm TB is superior to the 74mm TB. I don't have a supercharger, but do have a TPIS-modified LS6 manifold that has a 90mm LS2 TB. It is a nice mod that is almost non-detectable, and the cost is much less than a FAST/90mmTB. TPIS estimates a gain of about 18 rwhp over the stock LS6 TB.
Old Jul 13, 2006 | 10:02 AM
LS1Tech Co-Founder
01 why don't you try it and report back?
I'm thinking you will have less restriction, maybe make more power at the engine and less boost.
Old Jul 13, 2006 | 11:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
For a 410ci I would use the Edelbrock intake.It does gain power over the LS6 and evens out the cylinders.
Old Jul 13, 2006 | 07:30 PM
ujslost2's Avatar
Pro Stock- Im in the process of doing that. Im going to to compare the ls6 and a ls2. I will post the graphs soon. I allready have both just have to go to the dyno.
