Need place to tap Oil from motor!!
Old Jul 13, 2006 | 11:37 PM
2005suburban's Avatar
Default Need place to tap Oil from motor!!
Guys I built a 383 stroker and we are going to run 2 front mount turbos...
I was wondering where on a Chevy Small Block 1 Piece seal.... Would I tap into for oil???
Thanks alot guys!!
I will have some pictures up very soon!!!
Old Jul 14, 2006 | 12:26 AM
I have no idea where to do it?!?!?!
Old Jul 14, 2006 | 01:12 AM
LTLHOMER's Avatar
By the oil filter is where most guys do it...there's kits for remote mounting it with fittings built in or you can just tap it...where exactly I'm not sure but what kinda block is it?
Old Jul 14, 2006 | 03:25 AM
Boostaholic's Avatar
1st gen block?
Where do you hook up your oil pressure gauge?
Old Jul 14, 2006 | 01:12 PM
Its a post 87' 1 piece rear seal block....
Old Jul 14, 2006 | 02:09 PM
GrahamHill's Avatar
The guage hooks behind the distributor. There is a couple fittings screwed into the block riiiight behind the rear of the intake manifold. Maybe you could 'T' off the oil pressure sending unit.
Old Jul 15, 2006 | 08:14 AM
MiaSSmaro98's Avatar
correct there is a plug behind the distributor remove it and screw ur fitting in and done deal or get a kit that gos ontop of the oil filter
